TwinTurbo.NET: Nissan 300ZX forum - Re: car won't start please help
Subject Re: car won't start please help
Posted by LivinTheDream on September 13, 2008 at 2:54 PM
  This message has been viewed 91 times.
In Reply To car won't start please help posted by Z_Freak24 on September 13, 2008 at 12:57 PM
Message Since your acc isnt even doing anything or the things that work without the key like power seats then its a main power problem. id say either:
1. your battery is dead somehow or
2.your negative terminal has a prob or
3.the negative ground wire is bad. also if thats all good
4.the power supply wire that goes to the fusible link (which is responsible for distributing power thoughout the car) has shorted out. or
5. one of the fuses in the fusible link went bad if u hadnt checked that.
The manual is a blessing when it comes to checking electrical theres an online one on Zdriver.com if you dont have one. make sure and take out a fuse and use a test light (sending power thro one end) to check it becuase sometimes the break is so small you can hardly see it. really look into your battery first tho
